Websocket Server icon Websocket Server — WebSocket server for ARC: accepts clients, stores messages, runs per-message scripts, tracks connection status, supports debug, needs Windows admin Try it →
Looks like it can't find the cloud, which isn't surprising since if you look at the wifi you aren't connected properly.
It indicates the problem is with your wifi not ARC.
ah ok i check thanks
the wifi works. i can go on the internet. you have idea where to look? blush
If your connected to the internet it should work now...
no still desame
In the image you posted you have an error with your wifi connection indicated by the orange star, Windows should tell you what the problem is if you check your network settings.
you will require a connection to the internet to use the cloud service.
i gess its ok now.i install it as admin.
