Pandorabot AIML2 icon Pandorabot AIML2 — Connect ARC to Pandorabots AIML2 to run AI-driven virtual personalities for human-like text or voice chat, using API keys and script hooks. Try it →
#17
My computer is factory and it will play the audio of 2 You Tube videos at the same time with no errors.
#18
try one youtube and one from something else like a mp3 or something else.
#19
Better yet, Publish your project to the cloud in public mode and I will download it and see if I see the same issues. I will be away for a couple of hours but will check it when I get back.
#20
I tried what you suggested and everything works OK. I'll read up on putting something on the Cloud and attempt to do that.
It's to bad discussions go off the front page so fast, my "Text to speech servo movement" didn't get a lot of response.
#21
@d.cochran I uploaded my project "InMoov finger" to EZ-Cloud
#22
I got the same errors when I loaded the project. I started poking around and noticed that a lot of the servos in the Auto Position tool were not mapped to any ports. On a hunch, I mapped all of these to different digital ports. I then added a variable watch control (because I like to see my variables) and added a Speech Recognition command called BOZO that runs SAY("BOZO THE CLOWN ROCKS THE CAZBAH!") because he does, ya know. I ran said BOZO and got no errors. I then added a soundboard (PC). I added one of my favorite Wall-E sounds and then made the Bozo script play this sound while he says BOZO THE CLOWN ROCKS THE CAZBAH!. I get no errors.
I have uploaded this to the cloud. Please download it and let me know if this fixes your problem. I dont know that it will. I just know that I was getting the errors and now I am not. If it does fix the issue, I would remove the servos that are not being used yet from the Auto Position tool until you need to add them and when you add them, assign them to specific digital ports.
#23
Wow, was that ever a lot of work for you, Thank you very much. I will try out what you've suggested and report back to you.I'll mark this as resolved for now. Once again thanks!
#24
Ok I'll try that again. Resolved
