Sketch Pad icon Sketch Pad — Script-driven Sketch Pad for ARC: draw shapes, text, lines and faces via controlCommand() to visualize object locations, paths and robot data. Try it →
Error Message In ARC (Terms And Condition's)
Hello DJ Sures,
I have a question about whether Windows 7 is compatible with ARC? I understand that not all features are available on Windows 7 though I had an issue today. While I was working a pop-up came up. It said that it would be preferable that I contact EZ-Robot and suggest that ARC would be compatible to the platform I use. I use a Windows 7 laptop. It has a Intel Core i3 processor and has 8GB of RAM, 64 Bit. I understand that you recommend a core i5 processor and 4GB of RAM at minimum. Though I do not have access to a newer laptop yet.
Any response / help is appreciated,
Thanks, Joshua
Great to hear from you! ARC is supported by current versions of windows provided by Microsoft, such as 8, 8.1 and 10. EZ-Robot cannot guarantee correct operation on Windows 7 due to being a discontinued operating system. Windows 7 is a discontinued operating system by Microsoft, as mentioned in the popup you are quoting.
Have fun!
