Prevent PC Sleep icon Prevent PC Sleep — Prevents a PC from entering sleep mode via a tiny, resizable control-keeps the system awake while minimizing UI real estate Try it →
Netherlands
Error On Laptop And Pc, Cant Add Speed Recognition
Hello. when i try to add a speech recogniton, it pops up like this :
ee the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at EZ_B.SpeechSynth.StartListening() at EZ_Builder.UCForms.FormSpeechRecognition.(Object , EventArgs ) at System.Windows.Forms.Form.OnLoad(EventArgs e) at .OnLoad(EventArgs ) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.SetVisibleCore(Boolean value) at System.Windows.Forms.Form.SetVisibleCore(Boolean value) at System.Windows.Forms.Control.Show() at . (Object , EventArgs ) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.235 (RTMGDR.030319-2300) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder Assembly Version: 2012.12.28.0 Win32 Version: 2012.12.28.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/EZ-Builder.exe
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.235 built by: RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.232 built by: RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
EZ_B Assembly Version: 2012.12.28.0 Win32 Version: 2012.12.28.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/EZ_B.DLL
System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
FFMPEG Assembly Version: 2012.12.28.0 Win32 Version: CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/FFMPEG.DLL
aForge Assembly Version: 2012.12.28.0 Win32 Version: 2012.12.28.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/aForge.DLL
System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Web.Services Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
mwwqz2xw Assembly Version: 2012.12.28.0 Win32 Version: 4.0.30319.232 built by: RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
I have little experience with Vista but can you not select a language from a drop down menu in Advanced Speech Options? There is a topic about Speech Recognition not working only a couple of days old, in it are some screen shots of my Win 7 dialogue for Speech Recognition, is Vista similar?
Netherlands
Voice for Dutch is not supported in Vista.
You cant get it for Vista for Dutch.
If you install your system with Dutch Vista, it automatically tries to load the Dutch Version first. And bugs out on that.
If there is a 'language' setting. its prolly after this error..
Netherlands
I can download a free online like 'https://www.e-speaking.com/' for instance.
is there a 3th party voice which will work with ARC?
ARC uses the Windows Speech Recognition settings, library etc. so I doubt a third party software would work.
Looking at e-speaking, it uses Microsoft's SAPI interface too which would mean it wouldn't work for you either.
