is that cause i dont have voice recog?
— Edited
4 Participants
On Variable Changed
— Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions.
See if you can reach this site from a web browser on the same PC running ARC:
https://www.rssweather.com/
The example works for me. Check your internet connection is OK, that would be the only thing that could cause the RSS feed to to be fetched.
I got it working as well... even have it set up for a rss weather feed near where I live...
rich
can it be that my pc dont alow it?
@Nomad.... Both @Alan and @Rich asked you a question.... They can't help you if you don't answer their questions...
rr ah that will it the error
rich internet in ARC?
The answer to your problem is stated quite clearly in the debug across the bottom and in the script dialogue. You have an error in the syntax on line 1.
Since the example works fine for me and for Richard R I can only assume you have changed something within the script and done so without paying attention to the syntax of the command.
If you are unable to figure out what you have done post your project, without it I am unable to see the contents of your script and unable to advise you on the error other than what the debug already says.
I have no idea why you have posted the connection established script dialogue screen, it is of no relevance.
rich i forgot how to do that.copie to clipboard?
