Ultrasonic Distance icon Ultrasonic Distance — Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output Try it →
Error on Saving Project
Error On Saving Project
I recently started getting this error message... I can't figure out the cause. Has anyone come across this before?
Did you try to save it to a different known existing folder?
I'll try that next time the error occurs. It did save OK after I repeated the minor changes I made. But this has happened before and I can't see a pattern as yet. Leave it with me.
Ah, random things like this are always hard to figure out. Good luck.
The message explains that the computer is out of memory. Your project may be too large and exceed the amount of available memory. A suggestion is to crop audio files by maintaining the part played, specifically on long files. Audio files are generally the most significant cause of memory consumption.
I will examine the audio files, although there are only 15 of them - all MP3. One of my other robots projects has 65 audio files without a problem.
#6   — Edited
Close any other programs too. Free up as much memory as you can. How big is your project file?
oh and try saving to the cloud and see if that works.
No other programs were running. The project file is 37mb. I did notice something though. In this project, I am using the Soundboard PC ver2 which allows you to add actions. Previously I used Soundboard PC (ver1) and never got this error. Perhaps I should go back to using that as I can live without adding actions to the sound files.
That shouldn’t make a difference but if it helps, it’s coincidental. Use what ever works:).
