Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
Example Script For Facedetect.Vision.Detection.Haarrectangle
Hi,
I have some Python code working that uses CameraFaceDetection.GetFaceDetection(), and I will post this soon. But it only outputs the region where the face is.
I looked for an example script that calls FaceDetect.Vision.Detection.HaarRectangle, which I'm guessing gives exact coordinates.
Can anyone point me to such an example? The language doesn't matter, just so long as I can see most of the functions and parameters.
David.
CAmeraFaceDetection.GetFaceDetection() will return the Rect, CenterX, CenterY, IsFound and more. It returns an ObjectLocation which is packed full of coordinates and details.
The Rect will give you the exact coordinates. The CenterX and CenterY will give you the center coordinates. I don't think there is anything else you can expect. A graphic image only has X/Y coordinates, so a Rect is a summary of that.
What additional information are you looking for?
Perfect. I couldn't see these functions in any of the examples I looked at. I now have the center of the face, in Python syntax ('--' means tab):
f1 = _camera.CameraFaceDetection.GetFaceDetection() if f1.isFound == False: --print 'No face detected' else: --print f1.verticalLocation,f1.horizontalLocation --print f1.CenterX, f1.CenterY
Excellent! And the Rect within the ObjectLocation contains the size of the face:D
IS the face detection script example in ARC DJ
