Diagnostic Report icon Diagnostic Report — Collects and sends ARC diagnostic reports to Synthiam to help troubleshoot EZ-B and robot connection issues Try it →
Execute Scripts Or Commands With Http Get Commands
I think this is possible and has been discussed, but I can not find it. Is there a format to execute scripts or commands using an application that can send HTTP GET or POST commands but not be using a web browser, either with the HTTP Server or HTTP Server (custom).
I don't think I can do it with the HTTP Custom because it uses AJAX and I don't know how I would format a request (and unfortunately, the documentation is fairly minimal) but I thought someone was already doing this with the simple HTTP server, embedding the user name and hte request in the URL of the GET.
I also know I can do this with Telnet using the TCP Clients object, and I may use that for my solution, but it is a little more limiting.
I'll explain my goal in case it provides any other thought.
I want to be able to drive my robot from my Android phone or an Android Wear smartwatch. I don't want to use the mobile interface, I want to have an embedded computer running ARC performing a number of tasks, the remote interface just to give additional commands.
I have two applications that can easily send HTTP Get or Post requests and allow me to build custom interfaces. Anymote smart remote, and Tasker. With a Tasker plugin I can also send Telnet requests, and I may wind up going in that direction if I am wrong that this can't be done with one of the web servers, but that isn't really the direction I wanted to go. (I think I could also do it using Eventghost to receive the HTTP requests and then send telnet requests to ARC, and I am sure I could write a plugin or do something with the SDK once my C# skills are up to speed, but I could swear this is existing functionality and I just can't find the right nomenclature for the command).
#33
@Mickey666Maus, Thanks for the tip on how to do this in IFTTT !
I was able to duplicate your findings using Maker on IFTTT on simple commands like the Servo(d11,90) that didn't rely a return value like SayEZB("My voltage is" + GetVoltage() )
For the more complicated commands I created a script in EZB Script Manager and invoked it through IFTTT using ControlCommand ...It even worked on a complex action like DJ's battery level script.
IFTTT....... https://23.119.244.175:8020/Exec?password=admin&script=cc("Script Manager", ScriptStart, "battery level")
EZB script... SayEZB("I have " +round( ( ( getvoltage() - 7 ) / 1.2 ) * 100, 1 ) + " percent battery remaining")
Thanks, Frank
#34
@Mickey666Maus I think there have been some updates to IFTTT and I'm now getting "Applet skipped" messages
Is it still working for you?
Regards, Frank
#35
@faengelm,
Just wondering if you were able to determine why all of a sudden Ifttt is exibiting errors when communicating with ARC? Thanks much....Rick
#36
Hello Rick, I haven't seen those messages again and I use IFTTT fairly often
But, the actual response times vary quite a bit... sometimes within a few seconds, sometimes over a minute on the same applet
Frank
