Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
Exo Suit Using Ez Bits On A Different Scale/Power
here is an interesting idea making an exo suit using ezbv4 as the brain. and using ez bits as the structural elements only more powerful and stronger. using motors from Andymark structural elements from Tetrix robotics and using standard ez bits for the fingers and for the joints (wrists, elbows, shoulders, knees, and ankles. all will be a scaled up version of the ez bits for the feet the idea is kind of a hover board but not the real hover board for obvious reasons to where you don't have to walk around all the time. the first prototype will most likely be boxy if it even happens at all. for all who read this ,test ,try. i hope this idea will inspire someone somewhere to try this. let's make sci fi real life. thank you for listening.
and remember KEEP CALM AND ROBOT ROCK IT.
