Augmented Reality icon Augmented Reality — Overlay PNG/JPG images in real-time onto detected objects, faces, colors or glyphs using ARC Camera tracking; attach, preview, detach. Try it →
Expression Parser Broken: Boolean Expressions With Negative Numbers
The code below does not work:
1: ClearVariables()
2: $status = -1
3: $retry = 3
4: if ($retry<3 AND $status<0)
5:   #do something
6: endif
error:
Quote:
Error on line 4: Missing String Quotes or Invalid Expression at index 8: -
the code works when the status variable has a non negative number.
RepeatWhile and RepeatUntil are also affected
this was the initial code (stops working when status is negative)
repeatwhile($retry>0 AND $status<0)
  print("Do something here")
  $retry = $retry - 1
endrepeatwhile
to overcome the bug, i end up changing the logic and the code became more complex to read.
:loop
if ($retry>0)
  if ($status<0)
    Print("Do something here")
    $retry = $retry -1
    Goto(loop)
  endif
endif
These variations seem to work:
if ($retry<3) AND ($status<0)
           or
if (($retry<3) AND ($status<0))
repeatwhile(($retry>0) AND ($status<0))
fixed in next release
PS - also, thanks for the examples @WBS and @ptp . It helps identify the solution with use case examples. Usually someone just says "this doesn't work" and i have to guess what they were trying to do:D
Thanks
