Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
Expression Parser Broken - Length Function
The code below does not work:
1: ClearVariables()
2: $buffer = "foo;bar;quux"
3: $sepPos = 3
4: $len0 = Length($buffer)-$sepPos-1
error:
Quote:
Error on line 4: Operator '-' invalid for strings.
1st attempt with a different code:
1: ClearVariables()
3: $sepPos = 3
4: $len1 = Length($buffer) - $sepPos
5: $len1 = $len1 - $sepPos
same error.
2nd attempt (success)
1: ClearVariables()
3: $sepPos = 3
4: $len2 = Length($buffer)
5: $len2 = $len2 - $sepPos - 1
it seems the the parser assumes Length function returns a string ?
Code:
1: ClearVariables()
3: $sepPos = 3
I ran into this issue myself, if you don't want to separate it over multiple lines you can cast the length in an int. I guess it is just one of the limitations of not declaring variable types.
Code:
ClearVariables()
$sepPos = 3
$len0 = CInt(Length($buffer)) - $sepPos-1
Print( $len0 )
yes is another away to skin the cat...
i had other similar issues with other functions too.
I don't agree with "it's just one of the limitations of not declaring variable types" mainly because of this:
$rLen1 = IndexOf($buffer, ";")-$len1-1
and it works, one function and two math operations.
Length() is returning the correct type (integer), only when combined behaves differently i'm guessing is really a parser issue.
Makes sense.
fixed in next release
Thanks
It seems I'm facing the same issue. I just installed the latest version of EZB...
$encoderBVAR = $encoderB - $var
if ($encoderA < $encoderBVAR)
  $forwardmustwait = 1
  $pwmFR  = $pwmFR +$mod
  $pwmRR  = $pwmRR +$mod
  $pwmFL  = $pwmFL -$mod
  $pwmRL  = $pwmRL -$mod
  $forwardmustwait = 0
endif
> Error on line 45: Operator '-' invalid for strings.
Done (00:00:00.5009241)
Just a guess here but try
  $pwmFR  = $pwmFR + $mod
  $pwmRR  = $pwmRR + $mod
  $pwmFL  = $pwmFL - $mod
  $pwmRL  = $pwmRL - $mod
endif
Elfge, Dave is right. You will need spaces between the operation commands.
