PWM Slider icon PWM Slider — Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection. Try it →
Gibraltar
Ez-B Conection Brownout
hi all still having problems getting started i just got my pc reformatted (windows xp) and still no luck got this msg in fermware updater
Attempting connection to COM3 Comm Err: The operation has timed out. BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String portName) Disconnected
please help i dont know what else to try i've had a new chip from The Master got new rechargable batteries (fully charged) new BT dongle witch paired ok using windows BT stack other than taking a solering iron to it i'm stuck just a bt LED that goes solid for 2 or 3 seconds and a big blue LED that flashes not pulses and laughs at me
Spain
That is the general error message when you can not connect. Have you read the tutorial on Bluetooth connection? He has written code pairing: 1234 in: Assign Bluetooth / Bluetooth on small icon that appears at the bottom of the screen? To "find devices" in the Bluetooth menu appears windows xp device called EZ-ROBOT? If you give us that information we could help you, greetings.
Gibraltar
yes i've seen tutorial and paired ok but still only see LINVOR witch i'm led to believe is ez robots bluetooth name until updated but i cant get that far.
translated with google traducido con google
Sí que he visto tutorial y emparejado bien pero aún así sólo se ve LINVOR me llevó a creer que es EZ ROBOTS nombre de Bluetooth hasta actualizada pero no puedo llegar a eso todavía
Try using a USB bluetooth from another vendor.
