Com Port Manager icon Com Port Manager — Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART. Try it →
Ez Robot Standard Servos
Hello
I have a question about the standard servos in the EZ Robot Kit. I received the replacement servos that were originally bad. I understand that problems happen in every business, no fault here on EZ Robot side, and would just like to say, very impressed with how it was handled. :) Back to my question ... lol No sense in throwing a servo away so I tinkered (by the way that is my robots name ... Tinker) with them and got 3 of the 4 working right. One had a gear with some stripped teeth, probably happened after the motor dropping down. I know. I know, is he ever going to get to the question? I was going to try and order some new gears and wondered what model they are?
Thanks ... Herr Ball
They are Futabu - rebranded from the factory with EZ-Robot. The Futabu model number is on the servo:)
DJ meant Futaba:) I believe the internal gears are the same as Futaba S3003.
Ok Im I the only one noticing his avatar? LOL:D Cracked me up!
