Are the EZ Robots that are scheduled to be shipped this month compatible with sensors that are often used with Arduino projects?
Such as:
Barometric Pressure Sensor Breakout - BMP180 -> bit.ly/1m5FbyR
Speech Synthesis Settings
— Configure Windows Audio.say()/Audio.sayEZB() TTS on EZB#0: voice, emphasis, rate, volume, speed/stretch and audio effects; copy control script.
Such as:
More than likely it'll work. Im on my phone right now but when i get to a desktop i will look at the datasheet.
Yes it will work on the V3 and V4 since it is I2C. You will need to know the I2C commands required to read from it through. Check the datasheets and also read up on I2C if you plan to use one, I2C can be confusing.
@Rich Thank you for the fast information.
That's Rich for you.
