Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
Yes, the ports are the same, and the program and functionality is similar, but the use of both is either really difficult now, or not possible. It would be more feasible to have 2 EZ-B V4's. More ports, more power, and better connectivity. Plus there is no issues with having more than 1 ez-b v4 in a robot.
Just know that some specific controls in ARC only work with the first connected ez-b. This just means that you have to plan what your first connected ez-b will be doing, and where to place it.
I interpreted your question differently. I think you are asking if you can follow the same instructable that was written for a V3 with a V4 instead.
Answer is yes. V4 has more ports, the connection is WiFi instead of Bluetooth, so there will be a difference there, and servo positions range from 0 to 180 instead of 0 to 100, so some instructions may need modification.
If you provide the link to the instructable, we can point out any needed modification.
thanks guys, sorry thetechguru, i was in a rush when i was typing so i meant a youtube vid, but anyways here it is
