NMS Navigation Data Grabber icon NMS Navigation Data Grabber — Query NMS lidar scan data by angle, with control commands for range, arc extremes, and obstacle checks from the latest scan. Try it →
Ez-ai Is Ready For Use Is Your Willing To Do A Bit Of Configuration Yourself
Ez-Ai Is Ready For Use Is Your Willing To Do A Bit Of Configuration Yourself
This thread contains the more recent information about EZ-AI. For information about EZ-AI visit https://www.ez-ai.net And visit the plugin page at https://www.ez-robot.com/EZ-Builder/Plugins/view/123
#105
The rerecorded installation video is posting now. It looks like a couple of hours before it will be complete. You can find the installation video at the bottom of the first post. It goes through every component used with EZ-AI.
#106
The patch to go from 1.0.0.4 to 1.0.0.5 has been posted to cochranrobotics.com also. This is a simple patch as there were no database changes. There are some additions that need to happen in the ez-ai.exe.config file. You will find those in the EZ-AI1005.exe.config file. Copy the contents to C:\EZ-AI\ and then go into the patch folder and execute SetupDatabase.bat to run the patch.
#107
d.cochran
Once I run through the video I'll probably have a few questions, can't wait to see this up and running here.
Her Ball
#108
I am having a bit of an issue with the Outdoor mode displaying the map on my inmoov computer. I am debugging the issue and will post another exe when this is corrected. I assume that others will experience the same thing.
#109
The fix has been published and works better than the way I was doing it. Its good to download and use but I will continue to test things out until the weekend.
#110
I'm not happy with the gps yet.let me work on that a bit more. It puts me at my neighbors house.
#111
Okay, I am happy with the Outdoor module. I had to put in 2 entries in the EZ-AI.exe.config file that are adjustable by the user. They are LatitudeShift and LongitudeShift. You can use these to adjust for your area. Google Maps comes close (its not really an issue with google but its easy to blame), but unless you live close to the equator, you will be a bit off. Use these adjustments to get you as close as possible to your actual location. This becomes important when you start doing navigation or using the emergency process. For Navigation, it's not that big of a deal but sending the police to your neighbors house might be...
I have put the latest files out. I will probably not be able to fix the emergency and Navigation pieces until tomorrow.
#112
hey, D.C.,
everything looks Amazing! Does it work with the EZB 3? And, I cannot find a link to download the program. All Links are 404 error.
