Dual Hbridge W/PWM icon Dual Hbridge W/PWM — Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning. Try it →
Ez-B Control Power Pins Above D14
There are a couple of pins above D14 on the EZ-B Controller If I have the batteries plugged into the power port can I also plug power onto these pins as well. What are the requirements? What is the best way to use them? What is the primary purpose for these extra power pins?
Those pins are additional power pins to connect another device. You do not provide power to those pins. You can only take power from the pins. They are powered by the same voltage regulator as the rest of the pins.
