Lewansoul Servo icon Lewansoul Servo — Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation. Try it →
Ez-B In Wall-E Still Failing.
once again, I have tried to run wall-e and the ez-b turned its light off again, disconnected from my laptop, and sent the servos berserk. How ever, the software did not freeze up this time. this time it failed when I tried to drive forwards. Custom Movement Panel configured to work with him right. I pressed forward, he went backward, and I pressed stop. bam. the ez-b disconnects, and goes berserk.
This is deeply bugging me as I really want to have wall-e up and running again. could we please take a look into this issue? Dj sort of dodged it last time.
Here is the debug:
EZB 0:
EZB 1:
EZB 2:
EZB 3:
EZB 4:
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
Camera Disabled
Camera Disabled
Camera Initialized: Wireless Video Device @ 160x120
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
Speech Recognition Culture: en-US
Loaded speech recognition successfully
Attempting connection on COM15
Connected to COM15 at 9600
EZ-B reports EZ-B Firmware V16
Connected
Comm Err: The operation has timed out.
BbytesToExpect: 1
Received:
Disconnected
Disconnected
Comm Err: Not Connected
BbytesToExpect: 1
Received:
Disconnected
Disconnected
and if the +5 is reading 0 volts its either a battery or ez-b issue.
VCC should always read 5v when the board is powered up, even if not connected to a PC.
Go through the diagnostics tutorial and check the board out properly before assuming it dead. It's probably best to do that when relaxed and with a clear head.
It appears that the ez-b is not dead. After unplugging everything it powered on fine. I will see if just running it is causing the failure.(not likely) then I will see if one of the servos is causing the glitch. Unfortunaty my other computer is too slow for Bluetooth. We will see if the problem involves just the ez-b tomorrow.
