Cognitive Sentiment icon Cognitive Sentiment — Detects positive sentiment percentage of input text using cognitive ML; returns $SentimentPercentage, shows face, graph, and status for analysis. Try it →
Ecuador
Ez-b Is Crazy! When A Color Is Following.. Help :(
Ez-B Is Crazy! When A Color Is Following.. Help :(
Hi!... I have been developing my own application for Ez-B.. my robot is following a color, it is fine, but when I remove the color, the robot is moving in the direction where he saw last color I am using an Hbridge... here is the code...
private void timer1_Tick(object sender, EventArgs e)
        if (!_camera.IsActive)
            return;
            ColorDetection.ColorEnum color = (ColorDetection.ColorEnum)comboBox3.SelectedItem;
            ObjectLocation objectLocation = _camera.CameraBasicColorDetection.GetObjectLocationByColor(color, 10, (byte)trackBar1.Value);
            _camera.UpdatePreview();
                if (!objectLocation.isFound)
                    return;
                    if (checkservo.Checked)
                        int position = _ezb.Servo.GetServoPosition(Servo.ServoPortEnum.D12);
                        int positiony = _ezb.Servo.GetServoPosition(Servo.ServoPortEnum.D13);
                        if (objectLocation.horizontalLocation == ObjectLocation.HorizontalLocationEnum.Left)
                            position++;
                        else if (objectLocation.horizontalLocation == ObjectLocation.HorizontalLocationEnum.Right)
                            position--;
                        _ezb.Servo.SetServoPosition(Servo.ServoPortEnum.D12, position);
                        if (objectLocation.verticalLocation == ObjectLocation.VerticalLocationEnum.Top)
                            positiony++;
                        else if (objectLocation.verticalLocation == ObjectLocation.VerticalLocationEnum.Bottom)
                            positiony--;
                        _ezb.Servo.SetServoPosition(Servo.ServoPortEnum.D13, positiony);
                    else if (checkmovimiento.Checked)
                            _ezb.Digital.SetDigitalPort(Digital.DigitalPortEnum.D1, false);
                            _ezb.Digital.SetDigitalPort(Digital.DigitalPortEnum.D2, true);
                            _ezb.Digital.SetDigitalPort(Digital.DigitalPortEnum.D3, true);
                            _ezb.Digital.SetDigitalPort(Digital.DigitalPortEnum.D4, false);
                            _ezb.Digital.SetDigitalPort(Digital.DigitalPortEnum.D1, true);
                            _ezb.Digital.SetDigitalPort(Digital.DigitalPortEnum.D2, false);
                            _ezb.Digital.SetDigitalPort(Digital.DigitalPortEnum.D3, false);
                            _ezb.Digital.SetDigitalPort(Digital.DigitalPortEnum.D4, true);
                        else if (objectLocation.verticalLocation == ObjectLocation.VerticalLocationEnum.Middle)
                        else if (objectLocation.verticalLocation == ObjectLocation.VerticalLocationEnum.Top)
                        else if (objectLocation.horizontalLocation == ObjectLocation.HorizontalLocationEnum.Middle)
                    string logMsg = string.Format("Objeto encontrado: {0} {1}", objectLocation.horizontalLocation, objectLocation.verticalLocation);
                    tbLog.AppendText(logMsg);
                    tbLog.AppendText(Environment.NewLine);
how do I get the robot when it detects anything stand still?
This may or may not be related to your problem but sometime when i start color/face/motion tracking, my robot just turn itself all the way to one side until i put something in front of him, then he will work as normal. Very strange! Hope DJ has some pointers at this.
reason for the brackets for _camera.UpdatePreview(); this should just be calling for and update on the camera console not a routine to be run within. Though I doubt this would be the solution. Secondly after the returns; there is no reason for the brackets as well.
Ecuador
... i am a beginner:) .. and _camera.UpdatePreview() DJ gave me this code.. someone can help me with a little example?
most of which you can grab from the example program he released just with modifications. He uses the D12 where your using D1-D4
the answer to this is within your question ...:)
*hint: Where is your code to tell the robot to stop when an object is not found?
Ecuador
all the night I have been writing the code... but.. I can not find the form to stop my robot... can you help me with a little example?? in my code ?? thank you very much:(
                if (!objectLocation.isFound) {
                  // STOP CODE HERE
                  return;
