PTI Lidar Plugin icon PTI Lidar Plugin — Pineapple Technology Industries Capstone plugin adds a secretive LiDAR unit to ARC for distance measurement. Try it →
Ez-b Keeps Disconnecting
Ez-B Keeps Disconnecting
So I finally got around to testing out my EZ-B. I have all my stuff plugged in, and as soon as I power it on, several of the items connected to it start running - without any controls associated. It connects up just fine but a soon as I attempt any control it disconnects. My thoughts are that because a couple of things are already running, as soon as I try to do anything else it is browning out. I am using the battery pack that came with it.
Thought: Should I disconnect all peripherals then power it up and slowly add items and test their control that way? Also, what would be an optimal battery pack to work with?
@Bret.Tallent I would not consider modifying the board. If you make a mistake, it's ruined. That'd be a pricey mistake:)
The additional power module should be available in a week
why not run power for your fan direct from battery. you can use a switch to trigger one relay to turn on ez b and another relay to turn on any other powered components, that way power is not coming from ez b and you will have a easy on off switch for your bot. i can give you directions and schematic for wiring. it may sound complicated but this is how we power pretty much anything in automotive customization.
@jstarne1 The relay will draw more current than the fan. The problem is he was running all of those peripherals off the 5 cell standard battery pack. That's only 1 amp, at max. I doubt it's even 1 amp with AA's. He'll be fine with a more powerful battery pack. I think the dudes that use lipo's know where it's at. They get 3-4 amps out of those things, and they're tiny and light.
We should start carrying more powerful battery solutions.
I got a Thunder Power RC LiPo from local RC shop 910mAh works great, size of two AAAs.
Using a transitor to turn stuff on and off is really easy.
  1. Get a TIP120 Darlington Transistor.
  2. Connect power to whatever you want to turn on and interrupt the ground with the "emitter" and "collector" from the transistor.
  3. Connect a wire from the PWM of one of the Digital ports to the "base" of the transistor.
  4. The circuit will be open (off) until you switch the digital port to HI which closes the circuit and turns your device on.
A TIP120 transistor from Radio Shack is less than $2.
#15
Maybe i should turn one of those into an ez-bit.. give it 4 or 5 channels. put a filter on it too.
#16
@DJ -- I thought we had a deal! I'd answer the easy questions and you'd get more product and features out the door! :D
