Personality Forge icon Personality Forge — Adds a Personality Forge chatbot to ARC, giving memory, emotions, AIScript dialogue, persistent conversation IDs and speech/chat integration via API. Try it →
Ez-B Not Connecting To The ARC
I'm having trouble connecting my EZ-B to the software. The EZ-B bluetooth is connected to my computer, but when I try to connect to the software, I get a "could not connect to the EZ-B. Would you like to view the Connection Tutorial?". I ran the firmware update and received this message:
Attempting connection to COM3 Connection Failed: System.IO.IOException: A device attached to the system is not functioning.
at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at EZ_B.EZB.Connect(String portName) Disconnected
I'm running Windows 7 Ultimate 64 bit on a bootcamped Macbook Pro. I have built-in bluetooth.
Any advice is welcome!
I would try a PC or laptop. I think someone tried a bootcamped Mac awhile ago it had problems
See this thread Click Here
I don't have access to a PC, and I don't really want to buy one just for ARC. I'll keep trying the bootcamp, but if that continues to have issues, I'll look into parallels.
Thanks for the link!
So I removed the EZ-B as a bluetooth device and then added it again. It still doesn't connect to ARC. So I ran it through the firmware update again, and this message came up:
Attempting connection to COM4 Comm Err: The operation has timed out. BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String portName) Disconnected
any ideas on how to fix this?
Bootcamp is when you boot entirely into a copy of windows - it's the best way. I developed most of ARC last year on a Macbook Pro with Bootcamp. It works great. Parallels is a little more unpredictable and we dont' always recommend it becuase sometimes it works and sometimes it doesn't.
Sarah, almost every connection issue is due to an unusual configuration on the computer. Specifically, not the native microsoft windows bluetooth stack.
Firstly, check this diagnostic procedure: https://synthiam.com/Tutorials/Diagnostics.aspx
If that passes, then feel free to Contact Us to send in your board and i'll personally take a look at it for you:)
Also, when you attempt to establish a connection from the computer, what do the two LED's on the EZ-B do? There is a little red LED on the bluetooth module, and a blue status LED on the PCB.
Gibraltar
my bt led flashes, goes solid for three seconds then flashes again, the ezb led just flashes (not pulses). I've tryed windows xp pc bt stack with two types of dongles and windows 7 lap top with said dongles. i'm waiting for a new chip form Amy to arrive if i don't have any luck i'll send you my ez b to look at if thats ok
When trying to connect, the Bluetooth LED (red) stops flashing, and the PCB LED (blue) continues to flash. When the connection fails, they both resume flashing
@sarahjane3 If you'd like to send us the EZ-B for diagnostic and operation, feel free:) Contact Us and we'll fire you off the address info and i'll look at it personally. Usually it's simply bluetooth, but it's taken a while now. I feel bad and don't want to waste any more of your time. If you are certain the diagnostic procedure is fine ( https://synthiam.com/Tutorials/Diagnostics.aspx ), then let me look at it and make sure there is nothing wrong:)
