NMS Faux Odometry icon NMS Faux Odometry — Estimate pose odometry from movement distance for robots without encoders, calibrated by speed. Suited for DIY navigation; pose drifts with lidar. Try it →
Digital or analog servos
i want to know if the heavy duty servo can run as continous servo i mean that it can rotate about 360 degrees or it rotate about 180 degrees and if there is any heavy servo that works with ez-b and rotate 360 degree plz tell me :)
Spain
Ferrymostafa Hello! all servos work with ez-b, you can modify a servo for continuous rotation cutting a mechanical stop and soldering two resistors. I have done with servo mg995 of 10-15kg of force and am going to do with Turnigy servos of 33kg of furza s8166m. You can find tutorials on how to modify the servo. You can also search servocity, paying $ 20 more, you can order almost any servo for continuous rotation.
