Cognitive Sentiment icon Cognitive Sentiment — Detects positive sentiment percentage of input text using cognitive ML; returns $SentimentPercentage, shows face, graph, and status for analysis. Try it →
Yes, the EZ-B(3) can be connected using the WiFi UART. There are several hundred posts about how to go about doing that. Search the forum.
In addition, the V4 can connect via a router or adhoc to the PC, I guess pretty much the same way as the V3 modification works.
I did plan on doing a short tutorial on this however, since the Elechouse WiFi UART module I ordered requires more power than the EZ-B can supply it's sat on the back burner for now, to be honest I didn't want to get all involved with further voltage regulators to make it work. But the information on the forums (and there is a huge topic on it) should be enough to show what's needed and how to do it.
Thanks guys. Guess I wasn't very specific on what version of ezb.
Dj said this in another post I Forgot about.
"@technopro, you can connect 253 EZ-B's to a router - or you can connect to them directly."
