Output Audio From EZ-B icon Output Audio From EZ-B — Example ARC skill demonstrating converting, compressing and streaming MP3/WAV to an EZ-B speaker, with play/stop commands and TTS examples. Try it →
Ez-B Trouble Updating From V2 To V16
Firmware does not update via Bootloader, get the following error log
Warning: Line 2: Fixing Diff: 4 Warning: Line 710: Skipping Type: 4 Warning: Line 711: Impossible Diff: -11328 Address: 0x0, SB Size: 0x5880 Image OK
Apparently the Toshiba bluetooth stack is not compatible with the file transfer process. Changed to another laptop (Lenovo) using Win 7 bluetooth stack and the upgrade to V16 was successful.
I had a similar problem. I got it solved by uninstalling all the EZ-B software and then do a completely, fresh new install. Everything worked right away.
