Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
Resolved Resolved by MovieMaker!
Ez-b V3 Pooched?
Ez-B V3 Pooched?
After realizing that wall-e was being neglected I decided to pull him out. I realized that I had an alternative battery so I unscrewed the battery pack from the adapter and screwed in the new pack. I plugged it in and...
It didn't turn on...
I played with the wiring.
Nothing...
I switched back to the original pack.
Still nothing.
I thought it might be an adapter problem. So I took my dads multi meter and discovered... I don't know how to use a multi meter.
I turned the multimeter off and then inserted the probes into the jack on the adapter and found arcing. It was making sparks as current travelled through the multimeter.
This tells me that the adapter is getting current. So now I'm wondering that maybe my ez-b is pooched? Its not getting hot and nothing is abnormal on the board, so im left wondering.
  1. How to perform a test to see the problem?
  2. How to use a multimeter.
EDIT: I did the first part of the ez-b diagnostic check and it checked out. Now i'm at the part where it should plug in and flash the lights and it doesn't.
Part 2 shows that theres .01-.03v going through the ez-b. It sits at 0 when not touching.
Rich, good advice.
I forgot to tell him that D.J. has a trouble-shooting tutorial in the tutorial section.
Regulators are good. fuse looks fine. Nothing seems abnormal on the ez-b. Going to have my Dad teach me how to use the multimeter.
One thing to check is the actual power source output with your meter to make sure the input voltage to the EZ-B is at or above 5 volts dc. Also a continuity check with the meter could be performed on the fuse to make sure it is not open.
Are you using the original battery pack that came with the unit? Those had some issues with the contacts where the batteries plugged into them.
I use 2 different batteries, one is the battery pack. posting a video and will be available soon. will post when ready.
#16
The video plays but I don't see where a meter was used to measure the output of that battery pack. How much voltage is stored in that pack ?
