BV4615 RC-5 IR Decoder icon BV4615 RC-5 IR Decoder — Adds IR sensor support and button mapping for USB joysticks in ARC, enabling remote control functions; third-party hardware supported. Try it →
Looks to me that the 4/2 board has more going on with it. Bigger, more digital, i2c, adc ports and comm ports.
/2 comm upgrade is $29.99 and the IOTiny is $24.99. /2 has more pins than the tiny. Protocol for comm, I believe are the same on both boards.
Important to read the product descriptions
  1. IoTiny is a self contained tiny EZ-B that has 8 digital pins, camera port, external speaker port, 1 i2c and 2 adc ports
  2. Comm 2 upgrade is ONLY an upgrade to existing EZ-B v4 users
  3. EZ-B v4.x/2 is a complete self contained EZ-B with 24 digital ports, 8 adc, 3 i2c, camera, and built in speaker
Portugal
Thanks for the answers. What i ment is the comm board itself. See Pics.
and this:
The item you highlighted is the wifi antenna shielded by a metal case. All WiFi devices have a wifi antenna and module for wireless communication. Even in your laptop or mobile device. What would you like to know about it?
Netherlands
@DJ How does the IoTiny compair to the EZ-B v4 and v4/2 performance wise?
I'd like to use it to send serial commands to my arduino, which handles my navigation and add another camera. But the better the speed the faster I can load GPS waypoints and maybe add some SLAM to my project.
I'm upgrading to v4/2 in any case, the smaller format saves me from chopping up a v4:D
Portugal
Speed and range. Are they the same? Thanks.
You bet! The EZ-B v4.x/2 and IoTiny actually run the same new TCP Stack and the application protocol layer is the same as well. The performance will be identical between the two.:D
The performance of READ/WRITE is incredible with the new stack and cpu. The previous version's Microchip Pic TCP stack was the best solution at the time for the first generation ez-b v4. Now, with ez-robot partnering with mxchip, the new module was customized for our needs. The new RTOS is quite impressive as well.
Remember, the READ and WRITE of any UART/Serial features will be as slow as the selected baud rate. That means a baud rate of 2400 bps will pause/buffer communication until the data has been successfully transmitted. If possible, use a faster baud rate.
The IoTiny does not have input UART, however. The IoTiny has output UART on all 8 digital pins, but no input. You would have to communicate with i2c to arduino.
