ADC Value icon ADC Value — Display ADC port voltage and 0-255 linear values (0-3.3/5V); configurable board/port, units, multiplier and sample interval. Try it →
Is it possible to show an EzB V4 Info window for each EZB you have connected. I cant find a setting that would allow this window to show up for each EZB I am using. Any help is appreciated.
Hello @dbeard, the EZ-B info control only works for EZ-B (0) but you can always use getVoltage() and getTemp() with EZ-Script to get the voltages and temp from the other EZ-Bs you have connected to ARC. You can use the mobile interface control to display the values in real time if you'd like.
*Edited - there isn't a control command
