Wowwee MIP V2 icon Wowwee MIP V2 — UART interface to hack WowWee MIP with ESP32/ESP32‑Cam or EZ‑B v4 for ARC; hardware UART preferred, configurable power and baud 9600/115200 Try it →
Resolved Resolved by Robot Doc!
Ez-B V4 Not Connecting?
I'm trying to get my ez-b working. I connect to the wifi source made by the ez-b. Windows states its a limited network. When I try to connect to the webserver via ARC it says your not connected to a network in the browser. Any help? I've reseted the wifi chip and rebooted and still. I'm running windows 8.1 with the latest ARC .
Just point your browser to 192.168.1.1 and it should be the wifi config page if you've connected to the correct wifi network.
Here are the steps I take:
  1. I turn the ez-b on. It blinks the blue light slowly but continuously.
  2. I connect to the EZ-bs wifi network: EZB V4 41
  3. I open ARC. I click the circle icon. It loads the page and says Your not connected o a network. The wifi shows the ez-b as an unidentified network. 4.I try to connect to it through ARC. I get the could not connect error.
I do exactly as the getting started video shows and it doesn't work.
I can access the web server from my ipod but not the laptop.
Something in windows is not letting me access the web server. I need help to figure out what!
Like Rich has said, all you need to do after connecting to the EZB4 WiFi name is to open a web browser and put in the EZB4 IP address 192.168.1.1 Don't try to connect using ARC.
That will then put you into the EZB4 webpage to change the parameters.
I type 192.168.1.1 and it doesn't work. I have lots of experience with network stuff but I cnt figure out why thi isn't working. From what ive tested, windows 8.1 doesn't work with offline web servers. My router, and the ez-b's web servers don't work on it. I need to figure out why.
I discovered the problem. I had set up a static ip address config for my laptop and when it connected to the other connections they didn't know that to do. I need to end the thread, and since Rich answers almost everyones questions(great job by the way) I want to give it to robot-doc.
