Servo Script icon Servo Script — Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control. Try it →
The ground wire is Black - sounds like you have it connected backward. Be careful because plugging servos in backward will blow the chip.
On the EZ-B v4, the ground pins are very clearly marked with the color BLACK.
The EZ-B v4 will require at least 6.4 volts, otherwise the lipo power saving will kick in. You can disable the power saving under the Connection Control Configuration in ARC
Hey Dj I didn't put the wire in the ez-b wrong I just didn't put enough voltage to the ez-b :)
Did the EZ-B not tell you there wasn't enough voltage?
