Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
Norway
Ez-bv4 To Control Underwater Rov?
Ez-Bv4 To Control Underwater Rov?
Hi. I am curious if the EZ-Robot hardware and software might be a good solution as a control system for my underwater ROV that I am building.
Although I have tried to create something using arduino myself, the programming is really a steep learning curve for me.
I will be running a wired Ethernet connection from the surface and have a wifi hot spot in the rov to allow connection to the bv4. It must control 9 brushless esc's. 6 for movement (thrusters) and 3 for a robotic arm. Also one servo for moving the camera vertically. The esc's use the same signal as servo's do, so I don't think this will be a problem.
I will also need to control 3 relays.
I have this unit for sensing battery voltage and current draw: https://www.coolcomponents.co.uk/attopilot-voltage-and-current-sense-breakout-180a.html This can be connected to the ADC pins correct? This is made for 3.3volts, but can it still be used maybe?
I have this IMU from OpenROV that I want to use:
https://store.openrov.com/collections/frontpage/products/openrov-imu-depth-module
I see there already is support for the MPU-9150 chip. But is it possible to also get the depth and temperature rating from the MS5803-14BA chip?
I want all to be controlled with a gamepad/joystick. This means that multiple motors must react differently to stick movements. For instance, if I want the ROV to turn in place. 2 motors must turn clockwise and two counterclockwise.
Would all this be possible to do?
Br Ole
#33
After some more thinking, this is actually just the same as a normal tracked robot. I can treat it the same way, but I need to be able to turn left or right gradually while moving forward or backwards. This can't be too difficult right? I have looked at the roli code and searched a bit for something like this, but haven't found anything that does this yet.
Any suggestions?
#34
If turning while moving is the goal why not just use a rudder?
#35
A rudder will not work as the craft also needs to be able to move sideways. Instead of a rudder you could have the thrusters turn like a rudder, but that approach would complicate things a lot.
This video shows this type of propulsion in use.
#36
I see. What thruster configuration did you decide to go with?
#37
Nothing is fully decided yet but the "five thruster version" form the picture above is what I really wish to have and what my current frame is designed to use. This is also what the ROV in the youtube clip is using.
#38
Quick question. What is teh EZ-Script equivalent command for arduinos "map" command?
For instance if I want to take the joysticks -1 to 1 range and map it to 0-180 servo pos in a custom script?
#39
Er du her fremdeler Ole? Jeg er i ferd med a starte et prosjekt og lurer pa om det er EZ-B eller Arduino jeg bor satse pa, og horer gjerne fra deg hvis du har lyst til a dele erfaringer / lose problemer:)
Claus (Hadeland)
#40
Use multiplication:)
-or-
easier, assign the joystick to use a Virtual servo (v0-v99). And in code, simply get the virtual servo value. That way you can let the joystick control servo handle the range.
$x = GetServo(v2)
