Remote UI Client icon Remote UI Client — PC Remote UI Client for ARC enables remote robot control via customizable multi-page interfaces from other ARC instances. Try it →
Ez-robot Developers Kit
Ez-Robot Developers Kit
Dear ez-robot,
I got "EZ-Robot Developers Kit" recently. I have a question about battery.
For now, it is using "battery" for electricity. Could it be change to use "AC adaptor"?
Please help and looking forward to having your answer very soon.
Best regards, Ricky Ma 25 Aug 2014
hello yes you can use an ac adaptor but then it will work when plugged in to the wall
It depends on the voltage and the current of the AC Adaptor.
The EZ-B V4 can accept 4.5v to 16v with the ideal voltage at around 7.4v
You will also need to make sure the current output of the AC Adaptor is high enough to power the EZ-B V4 plus any other accessories driven by the adaptor. Most AC Adaptors are rather low current outputs, 1A, 2A or 3A usually, in some instances 5A. If you have a lot of servos this can require a great deal more than 5A and will cause problems.
Also, by using an AC Adapter you restrict the range your robot can physically move (if it is a moving robot). It stops becoming portable if it needs plugging in to a wall outlet.
But yes, you can use one just take the above in to consideration.
Dear Wolfie and Rich,
Nice to meet you both and many thanks for your helpful answer!
I will try to do with your solutions.
But I have an experience that I do mistakes to plug in wrong adaptor, then the board is broken. Besides, I will do it again by using your opinion!
Thanks and good day!
Also, make sure that you have the polarity of the barrel jack correct. It is important, and you could damage your EZ-B if it is not correct. The center part (post) must be Positive (+)
this adaptor can be used to when you dont have the batterie yet? adaptor
No. This charger will probably only charge at 1C or 1.3 amps. I am just guessing here.
You would want something like what DJ mentions above.
Patrick, that is a battery charger not a power supply.... Take a look at the ones DJ linked to.....
