Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
You can start here...EZB4 and here ARC and specifically the Camera
It would be very difficult to sit and type on how to use the EZB4 camera with such a broad based question... However, the simple answer is yes the camera (ARC) has colour, facial (with a plugin written by a member on here called EZ-Face) and object recognition... I learned by reading the above and when I got my EZB it made it much easier to get the camera up and running... Reading in the "Learn" section of this web site is a really good start... If you have any further specific questions after that we will be able to help you out...:)
Philippines
i have a project in school a robot that will work independent without using a remote control and only the program of a mobile robot work itself... here's what my robot to do: Line follower Robot (the color of the floor is white and the line is black), with robotic arm to pick the object inside the arena, and the robot that can recognize 3 different Shapes and Colors... i don't know if EZ-Robot is capable of doing all these things... i need some advice of what im going to do before buying 'cuz the price is expensive...
Shapes? Not quite yet, colours yes... Line following, again no problem... Robotic arm will be a snap with ARC's auto positioning control... It can recognize glyphs and QR code and rudimentary object recognition only (still a work in progress)...
Philippines
@Richard: Yes, shape... only cube, cylinder and circle(like colored ball)... btw thank you for the quick response:)
Hey, no worries... It might work, but as I mentioned object recognition needs a bit more work, but is looking very promising for sure... I am sure DJ has plans to get back to it at some point... Right now EZ Robot is focusing all of it's energy rolling out Revolution and the EZB4.... So currently EZ Robot can do about 95% of what you need... And programming is light years simpler than C using ARC software....
Cheers
Well object recognition is currently in the works. A beta version is available in ARC right now. You have to do a lot of training though in different lighting conditions.
Color is no problem. You an track as many colors as you want and what ever color you want.
There might be an issue with what you are looking to do based on the definition of Remote Control. If you want the robot to be fully self contained and not be run based on a wifi connection to your network, then this might not be what you are looking for. If you can put a small computer into your platform, like a windows based PC, Android device, or an IPhone then you can do most of what you are looking to do plus a lot more.
The EZB4 connects via wifi to one of these devices, which is where the programming logic executes. The EZB4 is used basically as a gateway to the sensors, motors, cameras and other components in your robot. Because of this, if the robot needs to be fully self contained, you would need a small form factor PC or an Android or Iphone to handle the programming logic side. This makes for a very powerful robot that can handle a lot more than the tasks mentioned above. It also allows you to program in any of the .net languages if there is something that the ARC software will not handle right now.
This thread will help you understand.
The Link
Line following using the camera is quite easy. Using the multi color tracking mode.
Having the robot arm pick up shapes and colors is also easy. The colors can be programmed individually. The shapes (long as they aren't very detailed, ie plain colored blocks work great or a yellow duck, etc).
Many people are new to object recognition here and have attempted to train their robots with complicated detail shapes. If you ever watch a robot video that demonstrates shape detection, they use plain shapes like a rubber duck or cups or blocks.
Everything you asked for can be done with a few clicks of the mouse in ARC.
