User Defined Function Example icon User Defined Function Example — Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent. Try it →
Resolved Resolved by Rich!
Ez-Robot H-Bridge Board Documentation
I have an extra EZ-Robot H-Bridge board. It has no part number on it I would like to operate the "spare" from an Arduino. I can't find any documentation on the use of the pins on this model on the internet.
Could you point me to some documentation on this unit so I can get it running from an Arduino Uno ? Power, Direction, Break, PWM (Speed) for motor A and motor B. It is not obvious from your video on connecting it to the EZ-Robot controller V3 to determine the hookup and procedure for operating it because that is contained in your H-Bridge object..
I know this won't go to the top of your list....(:-)... But if you had documentation on operating it, or could point me it would help.
Jim
In the tutorial DJ points to just substitute the EZB V3 for the Arduino
Thanks DJ and Rich ! Appreciate the quick turn-around.....
The tutorial Rich did gave the info I needed. Great Job ! My guesses on the triggers were incorrect. Will be using PWM separately on the motors.
Wish had found this without bothering you all. I looked, but my searches didn't find it. You have a great wealth of info on your site.
When I get done with this Arduino project, I will go back to my V4 and play. You have added a lot of neat stuff since I looked at ARC last !
The Arduino shields for motor controls all eat up Arduino pins I need for other stuff like wireless comm. And, they don't let you change them. This board just needs Digital Highs and Lows from any digital pins, and 2 PWM outputs for speed. You can pick which pins to use.... I'm in business !
Thanks again ! I consider this post closed.
Jim
