Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Germany
Ez-Sdk Sample Code For Jd :)
Hello, i am playing around with an JD-Robot and wanted to rogramm it in Linux. the small code works, and it print "HelloWorld" in the Terminal. But how can i make my JD move? Are there librarys, or just an sample code for movin JD would be enough:) Thanks in advance, Patrick.
OpenBot is a third party product and not supported by ez-robot. I have never actually used it, although I have seen some projects built with it. I have not seen a JD built with it because the code does not contain the Auto Position GAIT module.
If you are using Linux, I would recommend using the EZ-Mono SDK. The Mono SDK for EZ-Robot contains the Auto Position GAIT module, which will allow you to make JD walk. Here is a link to the Mono SDK: https://synthiam.com/Products/ARC
DJ, That is what he is trying to use. You posted the same link Patrick did.
Hi, @ thetechguru, thanks, just wanted to say that:)
I want an sample code which moves my JD-Robot that i know how to use Mono with my EZ-Robot, Patrick
Alan, he edited the post - it was originally about OpenBot.
Looks like he answered his own question:D
To use the Auto Position, this is a cut and paste of how to move servos..
    string ActionGUID1 = string.Empty;
    string ActionGUID2 = string.Empty;
void InitPositions() {
      // These are events from the auto positions
      ezb.AutoPosition.OnComplete += AutoPosition_OnComplete;
      ezb.AutoPosition.OnStartAction += AutoPosition_OnStartAction;
      ezb.AutoPosition.OnStartFrame += AutoPosition_OnStartFrame;
      // First we define the servos
      ezb.AutoPosition.Config.AddServo(Servo.ServoPortEnum.D0); // 0
      ezb.AutoPosition.Config.AddServo(Servo.ServoPortEnum.D1); // 1
      ezb.AutoPosition.Config.AddServo(Servo.ServoPortEnum.D2); // 2
      ezb.AutoPosition.Config.AddServo(Servo.ServoPortEnum.D3); // 3
      // Add a frame. The number of positions must match the number of servos. First position is for the first servo, second position is for the second servo, etc..
      // In this example, this frame sets all servos to position 90
      string frame1 = ezb.AutoPosition.Config.AddFrame("Frame #1", new int[] { 90, 90, 90, 90 });
      // Now we will add more frames...
      string frame2 = ezb.AutoPosition.Config.AddFrame("Frame #1", new int[] { 70, 20, 40, 10 });
      string frame3 = ezb.AutoPosition.Config.AddFrame("Frame #1", new int[] { 170, 140, 80, 160 });
      string frame4 = ezb.AutoPosition.Config.AddFrame("Frame #1", new int[] { 20, 70, 150, 100 });
      // Create an action by assigning a bunch of frames to it.
      // Rather than a frame being assigned to an action directly, it gets wrapped in an ActionFrame which allows you to specify parameters
      // the parameters are Delay, Steps and Speed
      // The Delay is how long in MS to delay between steps
      // The Steps is how large of a step to take (1 moves the servo 1 position per step, 2 moves the servo 2 positions per step, etc..)
      // The Speed is how fast to set the ServoSpeed. A -1 means do not change the speed. 0 means move the speed to 0, etc...
      ActionGUID1 = ezb.AutoPosition.Config.AddAction(new EZ_B.Classes.AutoPositionAction(
        "Test Action 1",
        true,
        true,
        new EZ_B.Classes.AutoPositionActionFrame[] {
          new EZ_B.Classes.AutoPositionActionFrame(frame1, 25, 3, -1),
          new EZ_B.Classes.AutoPositionActionFrame(frame2, 25, 3, -1),
          new EZ_B.Classes.AutoPositionActionFrame(frame3, 25, 3, -1),
          new EZ_B.Classes.AutoPositionActionFrame(frame4, 25, 3, -1),
          new EZ_B.Classes.AutoPositionActionFrame(frame3, 35, 1, -1),
          new EZ_B.Classes.AutoPositionActionFrame(frame2, 35, 1, -1),
          new EZ_B.Classes.AutoPositionActionFrame(frame1, 35, 1, -1),
        EZ_B.Classes.AutoPositionAction.ActionTypeEnum.NA));
      // Let's create a second action
      ActionGUID2 = ezb.AutoPosition.Config.AddAction(new EZ_B.Classes.AutoPositionAction(
        "Test Action 2",
        true,
        true,
          new EZ_B.Classes.AutoPositionActionFrame(frame3, 25, 5, -1),
          new EZ_B.Classes.AutoPositionActionFrame(frame2, 25, 5, -1),
    void AutoPosition_OnStartFrame(AutoPosition sender, EZ_B.Classes.AutoPositionFrame frame, EZ_B.Classes.AutoPositionActionFrame actionFrame) {
     Console.WriteLine("Frame {0}  (Steps: {1}, Speed: {2}, Delay: {3})", frame.Title, actionFrame.Steps, actionFrame.ServoSpeed, actionFrame.Delay);
    void AutoPosition_OnStartAction(AutoPosition sender, EZ_B.Classes.AutoPositionAction action) {
      Console.WriteLine("Action Started: {0}", action.Title);
    void AutoPosition_OnComplete(AutoPosition sender) {
      Console.WriteLine("Action Stopped");
void StartAction1() {
      ezb.AutoPosition.ExecAction(ActionGUID1);
void StartAction2() {
      ezb.AutoPosition.ExecAction(ActionGUID2);
void StopAction() {
      ezb.AutoPosition.Stop();
Thanks, but when i try to compile it (gmcs HelloWorld.cs) there is an error: HelloWorld.cs(2,0): error CS1525: Unexpected symbol `string'
Can you pls give me a complete code?
Not when I read it 4 hours ago:)
Maybe you opened it in a tab and only got to it after an edit? That sometimes happens when I am reading a bunch of new posts.
