Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
Ez_B.Roboquad.Roboquadcmdenum.Head_Up
When I execute this command or any other commands in the ARC the roboquad responds appropriately. I am executing this enum or any other and it does not appear to respond. Any ideas?
    Private Sub EzB_Connect1_OnConnection() Handles EzB_Connect1.OnConnection
        Timer1.Interval = 250
        Timer1.Start()
    End Sub
    Private Sub Timer1_Tick(sender As System.Object, e As System.EventArgs) Handles Timer1.Tick
        If (EzB_Connect1.EZB.IsConnected = False) Then
            Return
        End If
        CheckBox1.Checked = EzB_Connect1.EZB.Digital.GetDigitalPort(EZ_B.Digital.DigitalPortEnum.D0)
        CheckBox2.Checked = EzB_Connect1.EZB.Digital.GetDigitalPort(EZ_B.Digital.DigitalPortEnum.D1)
        CheckBox3.Checked = EzB_Connect1.EZB.Digital.GetDigitalPort(EZ_B.Digital.DigitalPortEnum.D2)
        CheckBox4.Checked = EzB_Connect1.EZB.Digital.GetDigitalPort(EZ_B.Digital.DigitalPortEnum.D3)
        CheckBox5.Checked = EzB_Connect1.EZB.Digital.GetDigitalPort(EZ_B.Digital.DigitalPortEnum.D4)
    End Sub
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        EzB_Connect1.EZB.RoboQuad.SendCommand(EZ_B.RoboQuad.RoboQuadCmdEnum.Head_Up)
    End Sub
Only that one command doesn't respond?
I tried several commands(Roar, Volume_Down, Twitch, etc.) in the button click event. I could not get any to be actuated.
There was another roboquad version that someone had with issues. It appeared to be different controller with different signals. I wonder if there are three versions?
You have the gnd connected also? I still have mine at the office which works great!
Did you disconnect the wire to the receiver? So only the ezb is connected?
You have the gnd connected also? Yes. Did you disconnect the wire to the receiver? Yes. So only the ezb is connected? Yes.
A very basic hookup, just two wires... I followed your tutorial for hooking it up.
The quad works just fine in ARC.
I close ARC and open up VS2012 and run the project and it does not respond to the SDK commands. I can shoot some video of it if you want something more tangible...
