To tech support the ezb4 controller voice is not on only I see a blinking light what can I do?
Jerseylance
— Edited
4 Participants
PWM Slider
— Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection.
@jerseylance.
A couple of things to check first...
1) Is the battery that is powering the EZ-B fully charged? If the battery voltage is too low, it won't speak.
2) Can you connect the EZ-B to ARC (solid blue, or solid green LED will be seen depending on what WiFi mode you're in when it's connected)? If it does connect, do you hear anything, such as an audio tone?
3) If the above two points have been ruled out (Battery is fully charged, and the EZ-B is connected the ARC), then click on the the link I have provided below, as it may be of help to you...
No sound from EZ-B
and a link to a detailed and excellent tutorial about connecting and using the EZ-B v4...
EZ-B v4 tutorial
I've tried everything but nothing doing, so what else can I do?
Please answer this question first. Does your EZ-B connect to ARC on your computer? Do you get a solid blue or green light on the EZ-B? If it does and you have no sound, one possible cause could be a faulty speaker.
If you are unable to connect your EZ-B to ARC on your PC, and you are hearing no noise whatsoever, it could be that the main processor could be faulty. I would suggest to use the "Contact Us" link and make a warrenty claim. When you are writing out the warrenty claim, make a reference to this this thread. But answer my questions first before you do.
It might be worth your while completing more of the tutorials in the learn section, as from your profile, I see that you have only completed one lesson for the mobile app. I highly advise you read and mark these lessons as they will help you out a lot with your EZ-Robot products.
@jerseylance - It's really hard to help you when you are not giving much information to go on. It would be helpful to the community if you could list out what troubleshooting steps you have taken.
Ok Zap or the community my controller was working unto last week when I would start it up. It would have a blinking light green then blue no sound. I've read and done the things that the forum would tell me but no sound or connection to the web.
Okay that's cleared things up a little bit more. I assume by "no connection to the web" you actually mean no connection between your EZ-B and ARC. Is that correct? If so, then it did work and had sound and did connect to ARC via AP mode (solid blue LED, not flashing) up until last week, but now it doesn't do either. Then it could be the ARM processor on the bottom board of your EZ-B is damaged. There was someone with a similar symptoms recently which was talked about in another thread. As this could be the case, read my post above about possible warrenty claim.
EDIT:
Below is the link to the other thread I was talking about...
EZ-B v4 broken. Please help.
From your previous posts, it appears that you are attempting to use the ezb on a bioloid robot. Can you please share your electrical schematic and information how the ezb is powered?
Circuits (pcbs) are fragile with incorrect electrical current configuration. Let us know the electrical schematic so we can identify the cause of how the controller was damaged and help prevent it from happening again.
The EZB is supreme to none but I would like it to work with the JD head which I think is awsume. The ezb4 is what I was going to show my class how the robot can interact with facial and color.
