Frequency Detector icon Frequency Detector — Detect audio frequencies via PC microphone (FFT), output a variable and drive servos within configurable min/max ranges with waveform feedback. Try it →
You have 4 apps in your account, and they are all PRIVATE. Only you can view them.
I'm still having issuses uploading to cloud. The file will save locally without issue. listed below are the error messages: System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown. at System.Text.StringBuilder.ToString() at EZ_Builder.Config.ConfigurationTools.GetConfigurationXML(ConfigurationV2 configuration) at EZ_Builder.EZCloud.FormEZCloudSave.NLbZw6H3qay() at EZ_Builder.EZCloud.FormEZCloudSave.k7QZwvuo8jB(Object , EventArgs )
Sounds like it’s exceeding the memory capability. Make your project smaller. 89 mb is very abnormally large. What could be taking up the space?
Maybe lots of sound clips in sound controls?
It is sound clips that are consuming much of the file size. The EZB is a great bit of kit. I have been looking for controller for sometime and when I came across the product and it's capabilities, I thought it would be a great fit for the 1:1 scale Astromech droid. It sounds like I will have to rethink the R2 audio effects.
Can the sound bytes be trimmed in length? Meaning, do they always play in entirety? Or can you trim the length for the part that’s played?
In the soundboard, you can right click on a file and trim it to cut the end out. This will save a great deal of space
I have the same issue with my B9 robot project. I have lots of sound effects and sound clips. They take up most of the room and I cannot save to the cloud. This doesn't interrupt or interfere with easybuilder interfacing over wifi with the several Ezb's on my B9. I just have to save it my project locally and make sure I have a back up here. Is there a reason why you need to store your project in the cloud?:)
