Audio File Out EZB icon Audio File Out EZB — Stream MP3 or WAV files from your PC to the primary EZ-B speaker for robot audio playback, alerts, music, and voice clips. Try it →
Ezb Camera And Case Trouble
Having a little trouble with fitting my EZB camera into case. As you can see in the pic below ( sorry it's the best shot I could get), the camera will not go any further down because of the round cylinder thing just below the lens. The cylinder is soldered to the board by not much more then a fine tread wire and I'm afraid trying to push it further will damage the camera. Has anyone else run into this?
can you try to place it first in the other part off the case.
Gibraltar
if you firstly put the lens through the upper case then offer the two parts together taking care to line the plastic lugs (marked red) outside of the soldered connections (marked yellow) it should fit tightly good luck
Ireland
yes I have similiar problem that component under lens is very proud on pcb and will not let lower casing push up over pcb I propose filing a little off lower housing otherwise I will put too much pressure on pcb
are these original cases from the cam?
I just had the same issue with a cam case I printed, Put in lens half first, its a very tight fit, but it works..
Ireland
original case yes ,it was so tight had to put quiet a lot of pressure to seperate housing problem now solved there are two vertical supports on lowering housing that support the pcb ,use a harp knife and trim both very little is necessary and it will remove the pressure on that component resting in front of pcb and allow you to re assemble quite easily Pat:P
