Hugging Face icon Hugging Face — Connects your robot camera to Hugging Face AI models for vision chat, object tracking, classification, captioning, and autonomous movement. Try it →
Ezb Configuration Control
Newbie to product. Question regarding message below.
1/12/2015 9:10 AM - Attempting connection on 192.168.1.1:23 1/12/2015 9:10 AM - Connected to 192.168.1.1:23 1/12/2015 9:10 AM - EZ-B reports EZ-B v4 OS 1/12/2015 9:10 AM - Welcome to EZ-B v4 Beta! 1/12/2015 9:10 AM - EZ-B v4 ID: 57-51-0-0-47-255-60-57-57-37-38-38 1/12/2015 9:10 AM - Connected 1/12/2015 9:10 AM - Setting battery monitor voltage: 6.6 1/12/2015 9:10 AM - Setting battery protection: True 1/12/2015 9:10 AM - Setting i2c rate: 100000
Read configuration from EZ-B
1/12/2015 9:10 AM - Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.Stream.ReadByte() at EZ_B.EZB.(Int32 , Byte[] ) 1/12/2015 9:10 AM - BbytesToExpect: 9 1/12/2015 9:10 AM - 1/12/2015 9:10 AM - Disconnected
  1. Why does it say, welcome to v4 "Beta"?
  2. What is this test looking for and why does it disconnect.
EZB does not have any devices connected.
Thanks for any help.
Back up a little... are you have connection problems? Have you done any of the tutorials involving connecting your ezb to your PC ten to ARC? See here... Connecting to your EZB4
Any chance your PC is an HP or Compaq?
PC is connecting and yes I have done the tutorials. Still use them as reference.
I was running the configuration control panel and that is the return I am getting. Also in the configuration panel I get the following results:
Bluetooth name:
Single_Value_Test: 0
You mean the connection control panel? Once you are connected to your ezb via your pc open ARC and you click on the silver flying saucer looking icon in the connection control panel. That will take you to the ezb web server where you can customize your ezb connection and such...
Not sure what Bluetooth name refers to... Bluetooth has nothing to do with the EZB4 at all (Bluetooth was used to connect to the older ezb3 controller)... I think you are over thinking things here a little and with "bluetooth" thing you might be barking up the wrong tree so to speak...
Pilot error here. I was selecting the V3 config panel. Thanks for the help. I am sure you will hear from me frequently. I am trying to hook up to a MIP Robot. We will see how this goes.
Thanks again.
Mike
Hey we all have been there at one time or another my friend, so no worries... If you need anything else just holler....:)
P.S. Can't help you with the Mip, though... However, I am sure there is someone else on the forum here that can....
Cheers Richard
