Get Line Containing From Array icon Get Line Containing From Array — Adds GetLineContainingFromArray() ez-script function to return the first array item that contains specified text, simplifying substring searches. Try it →
Ezb Firmware Update Failure   Help
ok all was working fine with ARC until i decided to upgrade to 12 26 version. down loaded ok then tried to run firmware update program. failure program reported io exception and no com ports are visable in pull down. ARC has no problem displaying corect com port just firmware utility. bluetooth device com port is correct. help as i am locked out now since my pc is one version newer then control pcb.
@mitchmen, we are not responsible for the bluetooth configuration of your computer. Do not be upset at us for your computer. You re-installed bluetooth and it works - be happy, not angry.
Second, if the sharp IR does not work, is it connected correctly? Is the EZ-B being disconnected from the computer? Are you receiving an error?
You will need to take a deep breath and provide more information so we can help you.
with the v12 firmware, the IR radar worked very well for me. after the Firmware update v15.2 no functional
again a bluetooth error?
Sharp Collision works very good Sharp IR Radar looks bad confused
I'll try later with my old laptop order to exclude errors
have a nice day eyeroll
Does it work on another ADC port? I tested it just now and works great. Maybe your ADC port is damaged from a short?
Hi Mitchmen14
Not a good idea to grip the EZB with the Robot Arm (as your pic shows) on the Bluetooth reciever it has delicate electronics and you may have damaged it??
The last time I got a reading like that it was a bad connector. When checking the voltage with a VOM it read low. Changed it out and tadaa!
okay so on the laptop I get the same results and I have the plug replaced I tested ADC 0-4 and 7, but unfortunately without success Perhaps the sensor is defective thanks for the help
#15
@mitchmen14 when you disconnect the sensor, and add a regular ADC control, do you see any values change while you touch your finger lightly on the Signal line of the ADC header on the EZ-B?
Also, putting a jumper between Signal and +5 on the ADC should show you a value. That will test your port to see if it is functional
#16
and I noticed something the ARC can not save projects on the pc I then tested the cloud and got an error (picture) I tried again to save a project on the pc and it worked crazy thing
save to the cloud does not work (on my pc) normal save works again I'm just happy that I can save again and hope it may help
