Robot Skill To Camera icon Robot Skill To Camera — Capture a robot skill's display and stream selected area as video to a configured camera device with FPS and live preview crop. Try it →
South Africa
Resolved Resolved by Rich!
Ezb V4 Incl Batteries
Hi peeps,
I'm new to the Ez-Robot community. I recently put in an order for the JD Revolution bot, excited about its arrival, even though it's in stage 2:)
I've been reading up about LiPo batteries and I am now sufficiently perplexed by the numerous complications surrounding all things LiPo...
From what I know, the JD kit includes a 1300mAh 7.4VDC LiPo battery (charger incl), but to better my understanding of what this means (pardon my ignorance if I ask stupid questions, but I am still new to a few of these things) this would mean that:
7.4 volt battery = 2 cells x 3.7 volts (2S)
Essentially, the battery pack is a 2-series LiPo battery pack. Subsequently at 100% charge, this battery pack would output roughly 8.4V?
From what I've read, LiPo batteries don't like being discharged past 80% of their capacity for numerous reasons, so I have the following question:
I'm assuming the EZ-B v4 does not cater for LiPo batteries going below 80% of their capacity as the the use of battery is not known upfront and for a number of other reasons. (also assuming this can be done easily as an extension by the end-user).
What's the best way to measure the voltage coming from the battery with regards to the EZ-B? For instance, the voltage reading detected by the EZ-B is 7.6, call an algorithm to move to the charging station or move to a safe zone and shutdown so as to limit the damage to the batteries?
I just need a basic idea of what needs to be done, I'll try and figure out the details as that's the fun part of the project:)
Just to give some context as to my experience level - I've been programming in C/C++/C#/Java for about 10 - 12 year now, but my experience with electronics is minimal. I know the bare minimum.
Thanks in advance!
Kind regards, Marius
User setable wouldn't be wise since a dead battery is a dead battery... it's not an arbitrary value... You allow a lipo to drop below 3v per cell and you may need to buy a new battery...Maybe you mean the ability to monitor the voltage value? Then maybe you can adjust your robot's behaviour before the EZB4 shuts things down?
It is user settable so that it can work with different battery voltages
You should see what one goes thru with lipos when used with RC Model airplanes, yikes, but is my favoroite hobby.
South Africa
Thanks DJ! I take it an event is "hook-able" within ARC / EZ-SDK where you will be able to handle the low-battery event?
I would like to handle the low-battery events as mentioned to either move to a charging station or shutdown completely.
#15
Mjv4721, with the SDK it is an event - however, the ARC it isn't... I can make an EZ-Script launch when it occurs if you'd like?
South Africa
#16
I am most likely going to fiddle with the SDK:D So I'll hook up to the event from within the SDK. Is the low battery event already available in the documentation? I know you mentioned that the low battery event is new to the EZ-B v4 or did I maybe misread that part? (So not sure if the documentation has been updated accordingly)
On a side note, will the ez-openbot project be maintained to for the EZ-B v4 specification?
Thanks for the cool product, looks amazing thus far. Can't wait to get my hands on my preorder.
