Openai Dall-E Image icon Openai Dall-E Image — Generate or edit images with OpenAI GPT Image from text or camera frames, with save and programmatic control commands. Try it →
Germany
Ezb Works Only In Jd, Not In Roli
Hi, today i have become for my Project a Rover. This works great, when i use the Rover in the torso from JD. But when i put this in my Roli, i have no function.
Battery is full loaded and i have check the contact. 8,38V When i activate, the EZB makes nothing. No flashing, no sounds, really nothing.
Its same as its off.
What can i do? I have check the distance from the Pins and the contacts, but its all ok.
Its really stupid.
Germany
#17
Is this better when i start a new topic?
#18
Yes @Stiko, it's probably better to start a new topic and add "Bug Report" as a tag. I have done some tests and found the following:
With the Ultrasonic distance control set to:
Trigger: D22 Echo: D22
Once unpaused, the 3-wire Ultrasonic Distance sensor works as expected.
Trigger: D23 Echo: D23
Once unpaused, The EZ-B red LED turns on, and it is locked up.
I am running an older version of ARC so @DJ may have already had a chance to look at this but only he will know.
