Audio File Out EZB icon Audio File Out EZB — Stream MP3 or WAV files from your PC to the primary EZ-B speaker for robot audio playback, alerts, music, and voice clips. Try it →
Resolved Resolved by Rich!
Ezb3 Won't Connect
OOPS! I posted twice.
Well, I will just use this space to ask another question.
I can't find all of the resources for the EZB3. All of the help and tutorials. I found a few, but not many. Where did they go? I was very familiar with the other setup and I could find anything. Now, the GUI is nicer, but I am lost.
All roads lead to V4. That is nice, but I am still using V3 also. I may upgrade at some point. But for right now, I want to use both v3 and v4 together.
It has been so long since I hooked them up that I don't remember how.
There should be a LEGACY section that has all of the original stuff.
Thank You.
@thetechguru, Where are the PWM ports located on the Sabertooth? I've looked at the 2X25 manual and the 2X12 Sabertooth I have here in my shop and cant seem to locate it.
I retract my suggestion. I got confused when searching another post for an answer. My sabertooth is sitting in a box waiting for my v4 to get here so I can start my big build.
Send Serial is the right way to control Sabertooth speed.
Thanks, Tech Guru.
I just hook up D0 to S1 and use Send serial by installing Sabertooth command panel. It will go in HIGH all the time, so I use send serial commands from the scripts.
Is this correct? this is what I am understanding.
@Alan, it cool cool . Sometimes that just happens. I often speak before thinking or checking fact. I'm constantly editing my post minuets after I send it off. ;) One of my many shortcomings. It's great that we can help and learn from each other and make sure things are right.
