Inverted Pendulum icon Inverted Pendulum — Balancing controller for Sainsmart v3 (and compatible) robots: PID tuning, real‑time telemetry, angle offset, movement and calibration via ARC. Try it →
It really depends what you're going to hook up to the EZ-B. Have a read of this section if my power supply tutorial. There's also a detailed battery section as well. It should hopefully tell you everything you need to know. Bottom line is, if your connecting servos to the EZ-B, you will need a supply with a high amp output depending on what you have connected, and a voltage output between 4.5v and 16v.
