Recorder icon Recorder — Record and replay EZB communications (servo & digital commands) with forward/reverse playback, save recordings and trigger them from scripts Try it →
Hi to all!
Long Long time ago i had so much time for EZ-Robots and my Inmoov but then comes a dark time of no Robot work, but now i am back in business!
A BIG HELLO TO: DJ - BOB HOUSTON - DAVID COCHRAN - WBS00001 and STEVE G
DJ you bring out a Version 2 of the EZB Controller 4 and a Upgrade for the Version 1.
I check out the WLAN is better and there a 2 ARM Prozessors.
I have 7 old Controller Version - so it will be for me interessting if i only will upgrade and not must buy 7 controller new.
If i will do the upgrade to Version 2 - i will have the same version withe the same technical data if i will buy the new ones?
OR is something missing in the upgrade what will be in the NEW Version?
Other Question:
Is there possibility to connect the controller via a LAN Cable?
Boris
PS: It feels nice to be back!
Welcome back!
No difference between upgrade kit and new systems, so might as well upgrade.
No ability to use a LAN cable, although you can now use USB cable (with a TTL adapter, and it uses the camera port).
Hello also to you TECHGURU!
Thanx for your Info!
So it will be time for upgrade!
But with the USB Port it might be an idea - I think its USB 2.0?
Boris
Technically, the EZ_B is a serial connection, although very high speed. Most TTL adapters are USB 2. Probably work on USB 1.
Hi Techguru,
;-) i am more thinking about USB 3.0, but if you say the connection via TTL is fast enough, its ok.
Boris
I must check also this TTL Connection, but first the new WIFI
