Intel Realsense T265 icon Intel Realsense T265 — T265 VSLAM for ARC: SLAM-based mapping and precise way-point navigation, low-power tracking, and NMS telemetry. Try it →
Ezb5 Coming?
EDIT False alarm or?...as you were...:) EDIT AGAIN I was right a V5 is in development....:)
@DJ, you forgot to mention this little addition in the release notes of the OCT 31st ARC update.... Maybe it's nothing but if you click on the "?" it gives a bit more info alluding to an ezb5 something.... "*Note This is experimental and used for the EZB v5 beta"... You sly dog, did you really think we wouldn't notice?... :P
@DJ. I would second the vote for USB connection. Would be great for those with embedded computers. However, I suspect market would be pretty small.
The USb connection would be nice! And maybe the ability to store a little code onboard? Perhaps a small 5kb storage area where you can put default able code for when the robot looses of connection, or you tell it to use that code.
Just some ideas. ;D
I will echo what Alan and Techno said... I would also love a USB connectivity option....
If no room, maybe a piggyback module, with communication, on board storage, etc. ?
Ron R
I would also love the option of USB. For other robots having on board computers. Or as requested, an add on board to v5
#15
Thanks for the feedback - USB expansion board is on the list.
@Richard, can you share what you're using for SLAM in ROS? I hear that SLAM is your priority of choosing ROS due to present navigation limitations of ez-robot. What sensors are you using? What sensors are popular in the ROS community for SLAM? Thanks!
#16
@DJ First off the fact that ARC has no current ability to do auto navigation is not a limitation, it's another feature that just hasn't been implemented yet;) ... Anyway, I bought the kit version of this about 2 weeks ago Oculus Prime ROV Just yesterday I got all the software loaded and the robot calibrated. Right now I have only been messing with the web interface to control the robot. I have also only touched on making room maps for the navigation part... So far so good. If you want when I really get it mapping and navigating I can post my results...
To answer your question... What I wanted to do with slam is have my robot not just wander around aimlessly trying not to bump into to anything, but to be able to send the robot on patrol routes or to certain areas of the house and have it navigate there by itself. The Oculus ROV does this pretty good. However, unless you are willing to cough up $1600 or so Canadian dollars for the "out of the box" full version be prepared for a lot of work assembling and installing/calibrating ROS on the kit version (as I did)....
Bottom line, it's a lot of work just to get a ROS robot to indoor navigate and that's with supported ROS robots like Oculus or Turtlebot.... However, when it comes to designing and building your own robot unless you're, well you or d.cochran, it won't be an option for 95% of us... I won't even go into mentioning how difficult it is to modify your bot with say a ping sensor or any other sensor for that matter. ROS's main focus seems to be sensors like Asus Xtion, Microsoft Kinect or a lidar of some type... You are going to need to learn Arduino as well as that is the preferred micro when working with ROS...
I have mixed feelings about ROS... It does pretty great stuff, but it takes a lot of work and effort to do it. I am going out on a limb to say it is still probably best left for University's, research and serious product development... One major advantage ez robot has over ROS (other than the obvious ease of use and versatility) is the ability to add peripherals or add-ons and interface them quickly.... Also the ability to rapidly test and knock up code...
One side benefit is I am really learning about network stuff, telnet, VNC, ssh and linux too... One last thing... I have yet again been invited to the local college here where I live to help with their inMoov build. It seems their robot program is building one...No doubt they are using Arduino and myrobotlab.... I will be taking my inmoov to demo in a few weeks.... They are about to discover that they are doing things the hard way when I demo how the ezb4 and ARC out perform Arduino and myrobot lab in every way....:)
