EZMQTT Broker icon EZMQTT Broker — Local MQTT broker for ARC: host pub/sub messaging on TCP port 1883, relay topics between publisher and subscriber clients. Try it →
Ezbot Connections To Client Mod
I attempted to switch my ezbot ap mode to client mode. part of the issue is that when attempting to access the web page which use an ip address of 192.196.1.1 my home router which is the same ip address come up in steady. after a few trys of rebooting I get the exbot web page manage to go in client mode the then my bot tells me that it cannot get internet access. so I can access the bot threw the ARC. I reset the bot network connects and its back and forth
any I idea on how to get around this
When I get the ezb web page and I have the choice to select in ap mode. Or wifi client . And l select client mode as in your video and provide my network information it said at the end that I am unable to connect to the network.
And the red light come on as it show on the video. The I reset and try again.
Also as I mention to you before I have to reboot by router a few time just to get the ez bot web page cause by router and the ezb web page. Use the same IP address. So it take a bit of time to do all of this. I spent a whole day trying to join the ez bot and my pc and ezb. Software
You have not answered the question about the EZ-B speaking. Does your EZ-B not make any sound? For example, does it not make a sound when the power is applied?
The red light flashing means the EZ-B is unable to connect to your network.
Again, the IP Address is not the same. I believe it is best for you to continue learning using the AP Mode (default mode) until you have a better understanding of Client Mode.
Client mode will also introduce lag and slower response time because the network connection is not direct. Using AP Mode (default mode) will be best at this time to enjoy your robot and continue learning:)
