Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Ezbsay() And Say()
Ezbsay() And Say()
Why is it my pc sound card works off the say script but I don't get any sound off the sayezb script. I wrote script and when I changed all the
sayezb (" I see a")
to just the sound board
say("I see a")
it only works out of the soundboard. Also the ez robot speaker does work and tells me when wifi connection is made. I did look and search for this but didn't get any answers. I also get this when I try to use the ezb to speak: " Error on line 7: Cannot change synthesizer's output while speaking. " I also tried the speech synthesis window and when I click for the ezb to speak, nothing comes out, only works with pc sound, Here is the error I got window
Speech Synthesis Error (SayEZB): System.InvalidOperationException: Cannot change synthesizer's output while speaking. at System.Speech.Internal.Synthesis.VoiceSynthesis.SetOutput(Stream stream, SpeechAudioFormatInfo formatInfo, Boolean headerInfo) at System.Speech.Synthesis.SpeechSynthesizer.SetOutputToNull() at System.Speech.Synthesis.SpeechSynthesizer.SetOutputStream(Stream stream, SpeechAudioFormatInfo formatInfo, Boolean headerInfo, Boolean closeStreamOnExit) at System.Speech.Synthesis.SpeechSynthesizer.SetOutputToAudioStream(Stream audioDestination, SpeechAudioFormatInfo formatInfo) at EZ_B.SpeechSynth.SayToStream(String msg) at EZ_Builder.UCForms.FormSpeechSynthesis.ARQMA3s6X6c(Object , EventArgs )
frank
#25
Richard, I thought when you run the sayezb script it does the connection. I had to go the the connection window and click connect, then the script runs. Sorry folks I just started this a few weeks ago and I apologize. Anyway look at the awesome great support DJ and all of you have. This community is awesome!
frank
#26
@Frank... no worries... we're all beginners at one time or another...
Cheers:)
