The Navigator icon The Navigator — Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints. Try it →
F-30 Revolution Six Vs. Six Hexapod
Please, does anyone know the difference between the Six with " F-30" and without? Thank you very much for answering. have no idea why this one has F-30 i n the name. wonder if it is different. It is my first EZ Robot or any Robot buy so have no idea if the F-30 means something or it is just an old name.
Also - the EZ-B may not be the latest version. You can tell when connecting to it via ARC. It'll say if it is an EZ-B v4.x/2 in the connection debug window
thanks, it does not says HD OR HDD....
You are not going to be able to tell from the box. You need to open it and see the label on the servos.
OMG i can't get to a store, have to do all online. thank you guru! only found this info which i don't understand....
look here.see pic.
As far as I know the packaging was not updated when the servos and EZ-B version were updated. The only way to know for sure you are getting the newer versions is to order from EZ-Robot. If you are trying to get a good deal from a less expensive seller, than you get what you pay for... The original version works fine, just the new servos are quieter and stronger and a bit more robust, the new EZ-B has a lot of features useful for DIY robots, but if you are just running SIX as designed, it is fine. EZ-B has upgrades to both available at reasonable prices.
not about price, they are all the same, but items from china over 40 dollars there is tax, makes it very hard to send as a gift because the receiver has to deal with paying for import tax before getting the box.
