Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Resolved Resolved by Jeremie!
FSR 400 Force Sensing Resistors to the EZB4?
FSR 400 Force Sensing Resistors To The EZB4?
Now I have another question for you Jeremie.
I need to know if you can tell me how I can attach there FSR 400 Force Sensing Resistors to the EZB4 for finger touch sensors?
The FSR 400 short-tail model is a single-zone Force Sensing Resistor optimized to use human touch to control devices for use in automotive electronics, medical systems, and industrial and robotics applications. FSRs are two-wire devices. They are robust polymer thick film (PTF) sensors that exhibit a decrease in resistance with increase in force applied to the surface of the sensor. This device has a 5.6 mm diameter active area and is available in 4 connection options.
Adding a spring to the gripper mechanism can indeed help to alleviate the load on the servo. The spring would absorb some of the force required to hold an object, reducing the strain on the servo. This could potentially extend the lifespan of the servo and prevent it from burning out.
However, it's important to note that the spring would need to be carefully calibrated to ensure it provides the right amount of force. If the spring is too strong, it could make the gripper too tight and potentially damage the object it's holding. If the spring is too weak, it might not provide enough support and the servo might still struggle.
In addition, the spring mechanism could potentially complicate the control of the gripper. The servo would need to work against the spring when opening the gripper, which could affect its movement. This would need to be taken into account when programming the servo movements.
Overall, while a spring mechanism could help to protect the servo, it would need to be implemented carefully to ensure it doesn't negatively impact the functionality of the gripper.
#26
@athena, what if the spring was being used as a cushion within the rotation part of the mechanism? I'm thinking it would act more like a shock to prevent the gripper from closing when holding an object when the servo is moved into the closed position.
Adding a spring as a cushion within the rotation part of the gripper mechanism could indeed act as a shock absorber. This would allow the gripper to have some give when it encounters resistance, such as when it's holding an object. This could potentially prevent the servo from stalling or burning out, as it wouldn't be forced to maintain a high torque when the gripper is closed.
However, this approach would still require careful calibration. The spring would need to be strong enough to provide a cushioning effect, but not so strong that it prevents the gripper from closing fully. It would also need to be designed in such a way that it doesn't interfere with the normal operation of the gripper.
In addition, this approach would likely require a more complex mechanical design for the gripper, as it would need to incorporate the spring within the rotation mechanism. This could potentially make the gripper more difficult to build and maintain.
Overall, while this approach could potentially help to protect the servo, it would need to be implemented carefully to ensure it doesn't negatively impact the functionality of the gripper.
#28
@athena can you give me tips on how to design this type of gripper so i can 3d print it?
As an AI, I don't have the ability to design 3D models. However, I can provide some general tips on how you might approach designing a gripper with a spring mechanism for 3D printing:
  1. Software: Use a 3D modeling software that you're comfortable with. Tinkercad is a good option for beginners, while Fusion 360 or SolidWorks might be more suitable for more complex designs.
  2. Design: Start by sketching out your design. Consider the size of the servo, the size and shape of the objects the gripper will be handling, and the location and strength of the spring.
  3. Servo Mount: Design a mount for the servo. This will need to securely hold the servo and allow it to rotate the gripper.
  4. Gripper Arms: Design the arms of the gripper. These should be long enough to grasp the intended objects, and strong enough to handle the forces involved.
  5. Spring Mechanism: Design a mechanism to hold the spring. This could be a slot or hole in the gripper arms, or a separate piece that attaches to the arms. The spring should be positioned so that it provides resistance when the gripper closes, but allows the gripper to open easily.
  6. Assembly: Consider how the pieces will fit together. You might need to design slots or holes for screws, or create interlocking pieces that can be glued together.
  7. Material: Choose a material that's suitable for 3D printing and strong enough for your application. PLA is a common choice for 3D printing, but ABS or PETG might be more durable.
  8. Testing: Once you've printed your design, test it thoroughly. Make sure the servo can move the gripper as expected, and that the spring provides the right amount of resistance. Adjust your design as necessary based on your tests.
Remember, designing for 3D printing can be a process of trial and error. Don't be discouraged if your first design doesn't work perfectly - learn from it and make improvements for your next iteration.
#30
@Athena  To measure downward pressure accurately using a Interlink Electronics FSRTM 400 single-zone Force Sensing Resistor, do I need a special electronic add-on board for measuring forces (or Pressure)? I found a board called MikroElektronika MIKROE-2065 or "Force click" that when a FSRTM 400 is attached to it is suppose to measuring forces applied to a force-sensing resistor. Is there any other method other then using one of these add-on boards that can accurately and simply measure pressure applied to a Force Sensing Resistor. The MIKROE-2065 setup is quite expensive at about $32 USD each. I'm looking for a simple and low cost solutution that will give ne very accrete pressure feedback from a Force Sensing Resistor.
To measure the force applied to a Force Sensing Resistor (FSR) like the FSR 400, you don't necessarily need a special electronic add-on board. You can create a simple circuit using a resistor and the FSR, and then measure the voltage across the FSR using an analog input (ADC) on your EZ-B v4.
Here's a basic way to do it:
  1. Choose a Resistor: The value of the resistor should be close to the resistance of the FSR when the desired force is applied. For example, if the FSR has a resistance of 10k ohms when the desired force is applied, you should choose a 10k ohm resistor.
  2. Create a Voltage Divider: Connect the FSR and the resistor in series to create a voltage divider. Connect one end of the FSR to the positive supply voltage (VCC), and one end of the resistor to ground (GND). The point where the FSR and resistor connect will have a voltage that depends on the resistance of the FSR, which changes with the applied force.
  3. Connect to EZ-B v4: Connect the point where the FSR and resistor connect to an analog input (ADC) on your EZ-B v4.
  4. Measure the Voltage: In ARC, you can use the ADC Read command in a script to read the voltage across the FSR. This voltage will change as the force on the FSR changes, so you can use it to estimate the applied force.
Remember, this is a simplified explanation and actual implementation may vary based on the specific characteristics of your FSR. Always refer to the datasheet of your FSR for precise information on how to use it.
Also, note that FSRs are not typically very accurate or linear, so they may not provide a precise measurement of force. They are best used for detecting the presence or absence of force, rather than measuring a specific force value.
#32
@Athena What is a more accrete peace of hardware to use to accurately measure force or pressure rather then using a Force Sensing Resistor? It needs to be small and inexpensive is possible.
